JT Reader
Supported Entities
- Free points
- Free curves
- Surfaces
- Solid bodies (JT B-rep)
- Embedded Parasolid (XT B-rep)
- Facets (triangular only)
- Parts
- Assemblies
- PMI (reference points only)
Import Options
Value | Description |
string |
Import only the specified layer filters. The string should be in the form of
all |
Import all generic attributes as metadata
(default).
%attribute1%attribute2%attribute3 |
Import specified generic attributes as metadata. The attribute names are
listed, separated by a character that you choose, and inserted as the first
element of the string. The example uses ' <name> |
on |
Assign body identifier as
metadata.
off |
Do not assign body identifier as metadata (default). |
0 |
Import B-rep or tessellation, with B-rep given preference. If B-rep is present, tessellation is not imported (default). |
1 |
Import both the B-rep and the tessellation. |
2 |
Import only the B-rep. If B-rep is not present, nothing is imported. |
3 |
Import only the tessellation. If tessellation is not present, nothing is imported. |
double |
A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance. |
on |
Read color attributes of geometric entities as metadata.
off |
Do not read color attributes (default). |
Parts |
Generate a full part-based hierarchy. |
BOMOnly |
Generate an empty part-based hierarchy. |
TreeOfComponents |
Generate an assemblies/components based hierarchy. |
PackIntoSinglePart |
Consolidate hierarchy into a single part. |
on |
Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
off |
Merge edges together during the import cleanup phase (default). |
string |
The string should be in the form of "%part1%part2%part3" . The
part names are listed, separated by a character that you choose, and inserted as the
first element of the string. The example uses '%' as a separator. You can choose
another character as a separator, in case one of the listed attribute names contains
'%'. HyperMesh will recognize it as it is the first character of
the string. |
on |
Import the model for visualization purposes only. This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses. |
off |
Import the model in the normal fashion (default). |
on |
Import free curves (wireframe entities) into the model (default). |
off |
Do not import free curves. |
on |
Import free points into the model (default). |
off |
Do not import free points. |
on |
Generate metadata with the original CAD hierarchy within the
part.
off |
Do not generate metadata with the original CAD hierarchy within the part (default). |
string |
Name of the CAD attribute containing the material name info of the current part. Default is "P_MAT". |
string |
Name of the CAD attribute containing the PDM mesh flag name info of the current
part. Default is "MeshFlag". |
string |
The string is prefixed to all metadata names. No prefix is used by
default. See CAD Metadata Naming for more details. |
string |
Name of the CAD attribute containing the PDM material ID info of the current
part. Default is "MID". |
string |
Name of the CAD attribute containing the PDM part number info of the current part. Default is "DB_PART_NO". |
string |
Name of the CAD attribute containing PDM property ID info of the current
part. Default is "PID”. |
on |
Read PMI data for reference points. New points are created and PMI attributes are attached as metadata. |
off |
Do not read PMI (default). |
string |
Name of the CAD attribute containing PDM major revision info of the current
part. Default is "Revision”. |
on |
Read surfaces, but do not create solid entities. |
off |
Create solid entities (default). |
Body |
Generate body-based component (default if
CreationType =Parts ). |
Part |
Generate part-based component. |
General |
Keep component as in CAD (default if
CreationType =TreeOfComponents ). |
Components |
Generate JT component-based components. |
on |
Split periodic surfaces to improve the quality and robustness of the import (default). |
off |
Import periodic surfaces as a single surface with a seam edge. |
on |
Create entity name as metadata (default).
FromBody |
Take entity from its parent body and create as metadata.
off |
Do not read tags. |
CAD units |
Keep the units of the CAD files (default for GUI). |
MKS [m kg N s] |
Convert to the corresponding units system. |
MMKS [mm kg N s] |
MPA [mm t N s] |
CGS [cm g dyn s] |
MMKNMS [mm kg kN ms] |
MMGNMS [mm g N ms] |
IPS Std [in pounds lbf s] |
IPS Grav [in slinch lbf s] |
FPS Std [ft pounds lbf s] |
FPS Grav [ft slug lbf s] |
Scale factor |
Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
string |
Name of the CAD attribute containing the PDM thickness info of the current part. Default is "P_GAUGE". |
string |
Name of the CAD attribute containing the PDM UID info of the current
part. Default is "UID". |
Supported Metadata
Type | Entities | Description |
string |
Identifier of the CAD body containing the entity. Generated when
string |
lines surfs comps |
Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model. Generated when |
string |
Hierarchy of an entity within a part. Generated when
integer |
comps if hierarchy as Assemblies; parts if hierarchy as Parts | Model units specified in the CAD file.
This is always generated. |
comps assems |
The <name> field is the JT attribute name and the integer/double/string is the value of the JT attribute. Generated when |
string |
points lines surfs solids |
The tag (name) of the entity as read from the CAD model, if one exists. Generated when |
