Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Smooth Particle Hydrodynamics (SPH), Finite Point Method (FPM) is a technique used to analyze bodies that do not have
high cohesive forces among themselves and undergo large deformation, such as liquids and gases.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can
be modeled as a simple line for FEA purposes.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts
or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell
meshing.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Before you begin, make sure the initial mesh is a regular mapped quad mesh, and not a
free quad mesh.
Figure 1. Pattern Based Mesh Refinement
From the menu bar, click Mesh > Edit > Elements > Refine by Pattern.
The Mesh Refinement dialog opens.
Use the Select node: Nodes selector to select the center node to start the
uniform mesh refinement.
For Select system, select a global or local system to be used for mesh
propagation and box alignment directions.
Define the Refinement box, which determines the constant refinement zone.
Elements inside this box should be the same size.
In the mesh size field, enter the fine mesh size.
The size should be smaller than the initial mesh.
In the Length field, enter the length of the refinement box.
To preview the box, click Review.
Figure 3.
Define the Transition box.
In the Length field, enter the length of the transition box.
The mesh will be transitioned to match the initial mesh.
Note: The
transition box should enclose the refinement box. The size of the
transition box determines how aggressive the transition will be. It
is recommended that you limit the transition to 1 element connection
3 elements (1:3).
