Delete Representations From the Current HyperMesh Session
Subsystem representations can be deleted from the current HyperMesh session.
When unloaded, FE entities of the representation do not exist in the current HyperMesh session. To completely delete the representation from a session, the representation itself can be deleted.
  1. In the Subsystem Browser, right-click on a subsystem(s) and select Representations > Delete > from Session from the context menu.
    The Delete Representations dialog opens.
  2. In the Delete Representations dialog, select the representations you want to delete.
  3. Activate the Delete representation from library checkbox.
    Note: The Study version will be incremented if a representation is deleted from the Library.
  4. Click OK.
