Load Representations From the Subsystem Library
Subsystem representations can be loaded from the subsystem library.
To exchange the current representation of the subsystem with a different one from the subsystem library, you can load the saved representation.
  1. In the Subsystem Browser, right-click on a subsystem(s) and select Representations > Load > from Library from the context menu.
    The Change Representation dialog opens.
  2. In the Change Representation dialog, Library tab, select the appropriate representations.
    The selected representations are loaded into the Representation folder on the file system as well as into the HyperMesh session.
