Save the Representation
Once you have created a subsystem and populated it with content, you can save the representation locally or save a revision to the Subsystem Library.
Representations of subsystems are saved in solver deck format based on the current solver profile.
  1. In the Subsystem Browser, right-click on a subsystem(s) and select Representation > Save from the context menu.
    The Save Representation dialog opens. A checkmark in the Available column indicates that the representation already exists in the local repository. A checkmark in the Library column indicates that a revision is already available in the Subsystem Library.
  2. Edit the Major Revision and Study Revision columns to reflect the intended revisions.
  3. Optional: To save parts locally, deactivate the Save to Library checkbox.
  4. Click OK.
