Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Review the selected Part Assembly/Part in HyperMesh
graphics.
This review function uses parallel processing and is used in case of huge number of
selected part and it takes time in normal import operation.
Once the model is displayed in the graphics, you can select unwanted parts in the
graphics and delete them; simultaneously, the Part Browser gets
updated.
Note: The number CPU set in the configuration general section is used
for parallel processing.
It is recommended to use this function before CAD Intersection or Comparison is
executed for full car model where it is not sure the parts are in right
position. Figure 1. Intersection Check on Each CPU
Right-click in the Verification/Comparison Browser and select Review
Results from the context menu.
