Part Classify
Group parts based on size and shape.
Groups are created under the Part Browser. To execute the classification, parts are mandatory.
- From the Verification Browser/Comparison Browser, right-click and select from the context menu.
- In the Similarity (%) field, type the desired same shape match%. The default is 50%.
- In the Tolerance field, type the search tolerance to use to find matching entities. The default is 0.1mm.
