Configure Model Checker
Save configurations for future use, import existing configurations into your current HyperMesh session, or append configurations on top of existing configurations.
Save configurations.
- In the white space of the Model Checker, right-click and select Save Config File from the context menu.
- In the Save dialog, specify a file name and directory to save the external .xml configuration file and click Save.
Add configurations.
- In the white space of the Model Checker, right-click and select Add File from the context menu.
- In the Add Config File dialog, navigate to the configuration file to add and click Open.
Import configurations.
- In the white space of the Model Checker, right-click and select Load File from the context menu.
- In the Load Config File dialog, navigate to the configuration file to import and click Open.
