Permas
Name Description Result Auto correction action Manual correction action
Youngs modulus and poissons ratio is not defined Checks if Youngs modulus has been defined for materials. Lists all materials that do not have Youngs modulus defined. Not supported. Opens the Material panel.
Poisson Ratio is not defined Check if Poissons ratio has been defined for materials. Lists all materials that do not have Poissons ratio defined. Not supported. Opens the Material panel.
Density is not defined Checks if density has been defined for materials. Lists all materials that do not have density defined. Not supported. Opens the Material panel.
Shell properties without thickness Checks if thickness has been defined for shell properties. Lists all shell properties that do not have thickness defined. Not supported. Opens the Property panel.
Component with missing material Checks if components are assigned a material. Lists all components that do not have a material assigned. Not supported. Opens the Component panel.
Component with missing property Checks if components are assigned a property. Lists all components that do not have a material assigned. Not supported. Opens the Component panel.
Component with solid and shells Checks if a component consists of both solid and shell elements. Lists all failing components. Not supported. Opens the Organize panel.
MPC (RBE2) with free dependent node Checks if dependent nodes of MPC (RBE2) are free. List all failing MPC (RBE2) elements. Not supported. Deletes the link between the independent node and free dependent node.
MPC (RBE3) with free independent node Checks if independent nodes of MPC (RBE3) are free. List all failing MPC (RBE3) elements. Not supported. Deletes the link between the independent node and free dependent node.
Unused materials Checks for materials that are not referenced by a component. Lists all unused materials. Deletes unused materials. Not supported.
Unused properties Check for properties that are not used in the model. Lists all unused properties. Deletes unused properties. Not supported.
Property is missing a card image Checks for properties that do not have a card image. List all properties that do not have card images. Not supported. Opens the Property Create panel.
Property missing mass value Checks if mass properties that do not have element mass defined. Lists all Mass properties that do not have mass assigned. Not supported. Opens the Property panel.
Damper property is missing Damping and Mass value Checks if Damper properties are missing the Damping or Mass value. Lists all Damper properties that do not have damping/mass assigned. Not supported. Opens the Property panel.
Beam Property missing HyperBeam Section Checks if Beam properties are missing HyperBeam sections. Lists all Beam properties that do not have beam section properties assigned. Not supported. Opens the Property panel.
Empty Components Checks if components have one or more elements. Lists all components that do not have elements. Deletes empty components. Not supported.
Unsed Sets Check if sets are not used in the model. Lists all unused sets. Deletes empty sets. Not supported.
Empty sets Check if sets are empty. List empty sets. Deletes empty sets. Not supported.
Empty groups Checks if groups have either a master entity or slave entity that are assigned a contact surface/set. Lists all groups with missing master and slave entities. Deletes empty groups. Not supported.
Empty contactsurfs Checks if contactsurfs are assigned any elements. Lists all empty contactsurfs. Deletes empty contactsurfs. Not supported.
Unused Sections Check if there are any unused Beamsections defined in the model. List all unused Beamsection collectors in the model. Deletes unused beamsections. Not supported.
Empty loadcollectors Checks if there are any loads in the load collectors. Lists all loadcollectors that do not have loads. Deletes empty loadcollectors. Not supported.
Empty Vectorcollectors Checks if there are any empty vector collectors. Lists all empty vectors. Deletes empty vectors. Not supported.
Empty assemblies Checks if there are any empty assemblies. Lists all empty assemblies. Deletes empty assemblies. Not supported.
Info
Number of Material Checks for the number of material entities in the model. Lists all materials in the model. Not supported. Not supported.
Number of Properties Checks for the number of property entities in the model. Lists all properties in the model. Not supported. Not supported.
Number of Comp Checks for the number of component entities in the model. Lists all components in the model. Not supported. Not supported.
Number of Groups Checks for the number of group entities in the model. Lists all groups in the model. Not supported. Not supported.
Number of sets Checks for the number of set entities in the model. Lists all sets in the model. Not supported. Not supported.
Number of Steps Checks for the number of step entities in the model. Lists all steps in the model. Not supported. Not supported.
