Advanced Query
From the Query panel, click the Advanced button.
The Advanced Query dialog is displayed.Figure 1. Advanced Query DialogNote: This option will only be enabled if a contour plot has been applied to the model.Tip: Part bound results are also supported in Advanced Query. Using Result Math to create expressions for part summations or max/min, the Advanced Query can be looped through the entire model and all loadcases to find the Top N/Bottom N ranked parts.
Select an advanced query option.
- Use config file
- User defined
If Use config file is selected, use the file browser
button to select a text file containing specific keywords.
The text file must contain the following keywords:
- TYPE
- Supported types are component, node, and element.
- OPERATOR
- Supported operators are >=, and <=.
- PERCENTAGE
- A positive integer between 0 and 100.
- LOADCASE
- Possible values are "current simulation", "current loadcase", and "all loadcases".
- ID
- The entity ID.
- YIELD
- The yield value.
Note: Lines that start with the "#" sign are considered comments and are ignored.See the Sample Configuration File for Advanced Query topic
If User defined is selected, use the Apply
to drop-down menu to determine the entities that the query will
apply to.
- All - Apply the query to all entities.
- Displayed - Apply the query only to the displayed entities.
From the second drop-down menu, select the entity type on which you
want to query.
Possible entity types include Components and Elements if the data type binding is elemental, or Components and Nodes if the data type binding is nodal.
Select a parameter from the list using the Value
drop-down menu.
If the entity type is set to Components, the options include the following operators:
- greater than or equal to, >=
- less than or equal, <=
If the entity type is set to Elements or Nodes, the options include the >= and <= operators, plus:- Top N
- Bottom N
These two options allow you to display only a certain number of entities in the table. For example, if you are querying elements, and the query returns 1000 elements, then you can set the top 500 elements to be reported in the table.-
Enter a value in the text field next to the drop-down menu.
Note: This value can be a real or decimal number if the operator is set to >= or <=. If the operator is set to Top N or Bottom N, the value must be a positive decimal number.
Remove all duplicates from the queried nodal data by enabling the
Remove duplicates check box.
This option is enabled when either:
- The native result binding is set to nodal.
OR
- The Average across component boundary option is selected in the Contour or Iso panels.
Note: This option is disabled for all query entity types other than node. - The native result binding is set to nodal.
- Specify a warning threshold by entering a positive decimal number (between 1 - 99) into the Warning threshold (1-99%) field.
From the Loadcase drop-down menu, select a loadcase to
apply the query to.
Option Description Current Simulation The current simulation step. Current Loadcase Cycle through all simulation steps. All Loadcases All available loadcases. -
Click Apply to apply your settings and start the
query.
The acquired data is displayed in a table. Based on the entity type, the table consists of different columns. Data can be sorted in the table by clicking on the header cells. When clicking on a colored cell, the corresponding component/node/element is displayed in the window.
After the acquired data is displayed in the table, contour plot information is displayed in the status bar area.
- Optional:
Click the View Table Only button (located at the bottom
of the dialog) to hide the upper portion of the dialog and display only the
table.
Note: Click Normal View to return to the previous view.
