Free Body Diagrams (FBD)
The Free Body Diagram (FBD) tool facilitates the extraction and post-processing of Grid Point Force (GPFORCE) results and can be used create and edit Free Body Diagrams (FBD).
FBD extractions are typically utilized for breakout and/or sub-modeling analysis schemes, where balanced "free body" sub-cases are extracted from a coarse grid model and applied to a fine grid sub-model for eventual optimization and/or analysis. FBD is also used to extract section resultant forces and moments (typically at the centroid of a section) for use in traditional strength calculations.
FBD Utility
The FBD utility extracts grid point force data (including forces and moments) for a user-defined element set and is useful for doing breakout modeling within a sub-modeling scheme. Results can be output for graphical review, a text summary table, and/or a formatted Comma-Separated Values (.csv) file which can be loaded into traditional spreadsheet software packages.
The data from the currently loaded model/results file and the selected load case/simulation in the Results browser will be used for all grid point force based calculations. The FBD utility currently supports ANSYS (Rst), Nastran (Op2/XDB), OptiStruct (Op2), Abaqus (ODB), and H3D result files.
Note: The following data types must be present in the result file to launch and use the FBD tool:
  • ANSYS: "Element Nodal Force as Vector" and "Element Nodal Moment as Vector"
  • Nastran/OptiStruct: "Grid Point Element Forces" and "Grid Point Element Moments"
  • In the case of OptiStruct H3D, make sure that GPFORCE(FBD) is requested for output when setting up the analysis.
  • Abaqus: NFORC Forces/Moments
Important: The Advanced Result Math template must be selected when loading the model and result files in the Load Model panel.
From the Results toolbar, click FBD .
The FBD Forces utility is displayed in the tab area and is broken down into three major sections, each of which corresponds with the process order of using the tool:
FBD section definition
Element based sections are defined and modified in this first step of the process. You can define multiple sections, associate elements, associate a node group (optional for resultant summation), or define other attributes (like a summation point, a coordinate system, etc.).
FBD plot
Once the sections are defined, you can plot results (Freebody or Resultant Forces/Moments) in this middle step of the process.
Display controls
The presentation of the results/plots are controlled in this final step of the process. The various controls allow you to determine how the vectors are drawn in the modeling window, view the results in a summary table, or export/save the results to a .csv or .fbd file.
