HV-3020: View Iso Values
Learn how to view iso values.
- View multiple iso values in the Contour panel
- View a single iso value in the Iso panel using Contour panel settings
- View iso values using displacement results
- Click the Iso panel button
on the Result toolbar.
OR
- Select from the menu bar.
The iso surfaces can be viewed from the Contour panel as well as the Iso panel. Choosing Show Iso Value from the Contour panel will allow you to view the iso surfaces according to the contour legend settings for the applied result type. On the other hand, the Iso panel allows you to automatically mask elements based on a user defined value for the result type that is applied in the panel. By using the option Use Contour Settings in the Iso Panel, you can view the iso surfaces for the results as applied in the Contour panel.
Viewing Iso Surfaces from the Contour Panel.
Viewing Iso Surfaces in the Iso Panel using Contour Settings
After you have created a contour of a model, you can view a single iso surface in the Iso panel.
