hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Averages the element integration point results to element values.
Averages the element node-on-element results to nodal values.
Sets the status of an element to active or inactive.
Assigns a value to counter.
Sets the status of a node to active or inactive.
Assigns a value to the counter.
