hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Compares the value associated with an element to the maximum of the element. If the value is greater than the maximum, it sets the maximum equal to the value.
Compares the value associated with a node to the maximum of the node. If the value is greater than the maximum, it sets the maximum equal to the value.
