hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Adds an item to a dynamic block.
Creates a dynamic block.
Finds an item in a dynamic block.
Frees a dynamic block.
Gets a pointer to an item in a dynamic block.
Reports the number of items in a block.
Resets a dynamic block.
Sorts the items in a dynamic block.
