Marks all channels to be skipped during translation.
Gets whether and how a data channel has been marked for recompution and how.
Gets whether a data channel is marked for translation.
Marks all channels for translation.
Marks a data channel for recomputation prior to being written out.
Marks a data channel for translation.
