Finds the value of a node.
Gets the unique ID of the XML file.
Gets the filepath of the XML file.
Finds a list of labels for the nodes or folders below the input node or folder.
Finds the variable name list of the nodes or folders below the input node.
Finds if the node or folder is an attribute.
Finds if the file is an XML file.
Sets the current XML file.
