lines
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Signals the end of a line.
Writes a line to HyperMesh.
Signals the beginning of a line.
Specifies the next segment in the current line as a piecewise cubic spline.
Specifies the next segment in the current line as an elliptical arc.
Specifies the next segment in the current line as a NURBS curve.
Specifies the next segment in the current line as a straight line segment.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
ON THIS PAGE
ON THIS PAGE
