nodes
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Associates a node to a surface.
Sends all the nodes stored in the buffer to HyperMesh.
Frees the memory associated with nodes stored with HMIN_node_store().
Retrieves the first pointer to a node.
Retrieves the next pointer to a node.
Retrieves the pointer to a node.
Sets up a buffer to provide a work area for nodes before transferring them to HyperMesh.
Writes a node to HyperMesh.
Writes a node, accessed by the pointer to the node, to HyperMesh.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
ON THIS PAGE
ON THIS PAGE
