Exports an export file.
Finds the name of a file.
Finds the format type of the exported file.
Finds the extension for the user input format.
Gets the format list.
Finds the starting page of the session that the export file starts with.
Finds the source that is being used in the export.
Finds the end page of the session that the export file contains.
Sets the name of a file.
Sets the format of the export file.
Sets the range of pages from the session that is to be exported.
Sets the source type that is being used in the export.
