Fits the model(s) in the current window so that all of the model(s) is visible.
Fits the model(s) in the current window so that all of the model(s) is visible through all time steps.
Gets the name of the current view marked as active.
Gets the ID of the image plane associated with the view.
Gets the number of pixels cropped from each side of the image plane associated with the view.
Gets the string name of the current view.
Gets the focal length of the current or specified view.
Gets the height of the image plane associated with a stored view.
Gets the width of the image plane associated with a stored view.
Gets the input principal point offset of a stored view.
Gets the input sensor height of a stored view.
Gets nine points which represent the lookat matrix.
Gets the status if the view is created from an image plane alignment operation.
Returns the orientation of the model within the view.
Returns the parameters describing the current view in the orthographic projection mode.
Gets the perspective angle of a stored view.
Turns the perspective mode on or off.
Gets the principal point offset of a stored view.
Gets the type of projection used by a stored view.
Gets the sensor height of a stored view.
Gets the orientation method of the camera top position.
Gets the orientation vector of the camera top position.
Gets a list of all memorized views for the current window.
Gets a 4x4 view matrix orientation of the active window.
Gets the "With Masking" state of a stored view.
Gets the z offset of a stored view.
Removes a view from the list of memorized views.
Renames an existing memory view with a new name.
Restores the current view parameters with the memorized view name.
Rotates the contents of the current window about the X axis.
Rotates the contents of the current window about the Y axis.
Rotates the contents of the current window about the Z axis.
Captures the current view parameters and saves it to a memory view with the given name.
Sets a view as active or not active.
Sets an ID of image planes to indicate that the image plane is associated with this view.
Sets the number of pixels cropped from each side of the image plane associated with the view.
Sets the focal length of the current of specified view.
Sets the input principal point offset of a stored view.
Sets the input sensor height of a stored view.
Sets the view matrix using nine points.
Sets the orientation of the model within the view.
Changes the current view when in the orthographic projection mode.
Sets the perspective angle of a stored view.
Sets the principal point offset of a stored view.
Sets the type of projection used by a view entity.
Sets the sensor height of a stored view.
Sets the orientation method of the camera top position.
Sets a 4x4 view matrix orientation for the active window.
Sets the "With Masking" state of a stored view.
Sets the z offset of a stored view.
Translates the contents of the current window to the given position.
Zooms by the given factor.
