Gets a list of descriptions for the data fields for the specified data source.
Gets a list of fields for the specified data source.
Gets a list of data fields for the specified data source using the sourcename.fieldname format.
Gets a list of the available data sources.
Gets the value of the specified property for a given source.
Gets a list of properties for the specified data source.
Gets the last occurred error description, or returns nothing.
Creates and returns a handle to the QueryIterator object that allows you to iterate through query results.
Gets a list of request fields in a query.
Gets the state of the remove duplicates option.
Gets the size of the entities selection set that will be used to query the HyperView database.
Sets the new value for a specified property for a given data source.
Sets the query string.
Sets the state of the remove duplicates option in the query handle.
Sets the selection set of a query.
Writes the query results to the specified file in .csv format.
