Adds a new result math expression.
Adds an external resource file to the current model.
Commits the result math expression to the data base to create a new user-defined data type.
Gets the alias string for the passed string.
Gets the result math equation string.
Gets a list of possible modes which can be used with the GetEquation command.
Gets a handle to the result math expression.
Gets a list of result math expression IDs.
Gets the ID of the result math expression.
Gets the label of the result math expression.
Gets a list of result math libraries.
Gets the number of additional result files that were loaded while using the Result Module to load models into HyperView.
Gets the number of arguments for a particular result math operator.
Gets the argument names for a particular result math operator.
Gets the syntax of the operator used in the expression builder when the default arguments are ignored.
Returns a brief description regarding the functionality of a result math operator.
Returns a description of a result math operator, and a brief explanation regarding the arguments and default values (if any).
Gets a list of operators for a particular library.
Returns the syntax of the operator as used in the Expression Builder.
Gets the file path of an external result math resource.
Gets the resource file name corresponding to a particular subcase ID.
Gets a list of result math resources.
Gets the file name corresponding to the index of the additional result file.
Gets the label of a particular simulation.
Gets the list of simulations for a subcase.
Gets the label of a subcase.
Gets a list of resources which contain the specified table name.
Gets the components associated with a table.
Gets the format and binding information of a table.
Gets the layer list associated with a table.
Gets the list of tables from all resources.
Removes an existing result math expression.
Sets the result math equation string.
Sets the label of the result math expression.
Sets the subcase ID in which the user-defined data type will be created.
