Gets the name of the nodal vector result that is used for animation.
Gets a list of datatypes suitable for animation.
Gets the scale mode.
Gets an analysis system number.
Gets the scale for X, Y, and Z.
Sets a specified data type as a new source for animation.
Sets the scale mode.
Sets the analysis system.
Sets the scale for the XYZ axis.
