Generates the linearized stress components for the Stress Characterization Line (SCL) specified by ID.
Gets a list of components that are currently being plotted.
Gets a list of all of the components that can be plotted.
Gets the data type being used for Stress Linearization.
Gets the CSV report filename.
Gets a handle to the Stress Characterization Line (SCL) by ID.
Gets a list of all Stress Characterization Lines (SCLs).
Gets the state of the "use current contour" flag.
Checks to see if the specified datatype can be used for Stress Linearization.
Deletes the Stress Characterization Line (SCL) specified by ID.
Specifies the tensor components to be included in the HyperGraph plot.
Enables report creation.
Sets the data type to be used for Stress Linearization.
Sets the plot layout.
Sets the plot window ID. This window will be used to plot curves.
Sets the path for the CSV report.
Instructs the Stress linearization controller whether or not to use the currently contoured data type for stress linearization.
