Appends a simulation to a derived subcase.
Appends a subcase to a derived subcase.
Gets the current simulation index of the subcase.
Returns whether or not the data component can be used with various complex filters.
Returns the data component list for the data type requested.
Returns whether or not the data component is transformable.
Returns the binding type of the data type specified.
Returns the format of the data type specified.
Returns a list containing all of the data types available in the subcase.
Returns the function type of an envelope derived subcase.
Returns the function type list for an envelope derived subcase.
Returns the index of the simulation in the original subcase which was used to create this particular simulation (simidx) of the derived subcase.
Returns the derived label of the simulation of a derived subcase.
Returns a list containing the labels of all the derived simulations.
Gets the result file ID corresponding to the simulation of a derived subcase.
Returns the ID of the original subcase which was used to create this particular simulation of the derived subcase.
Returns the type of the derived subcase.
Returns the list of possible types for the derived subcase.
Returns the ID of the subcase.
Returns the label of the subcase.
Returns the layer list for the specified data type.
Returns the number of data components for a particular data type.
Returns the number of data types available in the subcase.
Returns the number of derived simulations available in the derived subcase.
Returns the number of simulations available in the subcase.
Returns the simulation label corresponding to the index.
Returns a list containing all of the simulation labels in the subcase.
Returns the scale factor for a particular simulation index.
Returns the simulation sync value corresponding to the passed index.
Returns the type of the subcase.
Removes a simulation from a derived subcase.
Returns the function type of an "envelope" derived subcase.
Sets the type for a derived subcase.
Sets the label for a derived subcase.
Unloads the simulation corresponding to the index.
