Gets the enable state of the axisymmetry controller.
Gets the set handle from the axisymmetry controller.
Gets the set size of the axisymmetry controller.
Gets the axisymmetry setting.
Returns whether or not an axisymmetry exists.
Enables/disables the state of the axisymmetry controller.
Assigns a selection set to the axisymmetry controller.
Sets the axisymmetry setting.
ON THIS PAGE
ON THIS PAGE
