Gets the parameters which were used for a circular copy.
Gets the enable state of the symmetry controller.
Gets the state of one of the three mirror planes (xy, yz, zx).
Gets the coordinate system which was used for the reflect operation.
Gets the order of symmetry operations.
Gets the coordinate system which was used for the rectangular/circular copy operation.
Gets the parameters which were used for a rectangular copy.
Gets the set handle from the symmetry controller.
Gets the set size of the symmetry controller.
Sets the parameters which are used for a circular copy.
Enables/disables the state of the symmetry controller.
Sets the state of one of the three mirror planes (xy, yz, zx).
Sets the coordinate system which is used for the reflect operation.
Sets the sequence of the various symmetry operations.
Sets the coordinate system which is used for the rectangular/circular copy operation.
Sets the parameters which were used for a rectangular copy.
Assigns a selection set to the symmetry controller.
