Gets the list of input values for the current macro parameter.
Returns the name of the macro parameter.
Returns the type of the macro parameter.
Returns the macro parameter’s variable name, which is the name by which the parameter is referenced in expressions.
Sets the input values of the current macro parameter.
Sets the name of the macro parameter.
Sets the type of the macro parameter.
Sets the macro parameter’s variable name, which is the name by which the parameter is referenced in expressions.
