Use the Parameters Browser to parameterize the contents of a session file or report template and automate a variety of analysis processes with
the Parameters Browser.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
The HyperMesh Card Image panel is used to define solver specific data and review card information. The format of the cards and
the menus in the panel are defined in the export template, using HyperMesh Card Preview Commands.
A template file is organized into blocks and when outputting a database, HyperWorks Desktop processes a template on a per-block basis. Blocks are output in the order that they are defined in the template file.
The HyperWorks Desktop Template Functions are available to query information in the database, perform mathematical functions, and query user-defined
tables. A template function begins with the symbol @ and is followed by the variable arguments in parentheses. Template
functions are always placed between square brackets [].
Organization
Data Entry and Access
Template files allow you to access information from the HyperWorks Desktop database with two methods, data names and attributes.
Functions
The HyperWorks Desktop Template Functions are available to query information in the database, perform mathematical functions, and query user-defined tables. A template function begins with the symbol @ and is followed by the variable arguments in parentheses. Template functions are always placed between square brackets [].
Previewing Cards
Card images are described by a template file block. You can display the card image using the card previewer.
Node Output Example
This example demonstrates how to use template files to generate output files for nodes.
Element Output Example
This example demonstrates how to use template files to generate output files for elements.
Assembly Output Example
This example demonstrates how to use template files to generate output files for assemblies.
