tables
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Writes bool column data to a table.
Writes double column data to a table.
Writes entity ID column data to a table.
Writes float column data to a table.
Writes integer column data to a table.
Writes string column data to a table.
Writes triple column data to a table.
Writes unsigned integer column data to a table.
Writes a table entity.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
ON THIS PAGE
ON THIS PAGE
