hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Transfers the current values associated with the element centroidal results to hmreslib.
Transfers the current values associated with the element maximums to hmreslib.
Transfers the current values associated with the elements to hmreslib.
Transfers the current values associated with the node displacements to hmreslib.
Transfers the current maximums associated with the nodes to hmreslib.
Transfers the current values associated with the node results to hmreslib.
Transfers the current values associated with the nodes to hmreslib.
ON THIS PAGE
ON THIS PAGE
