*absorbloads
Absorb classical loads to engineering loads.
*absorbloads load_collector_id ?disable_value_comparison? ?renumber_flag? ?compression_status?
HyperMesh Tcl Modify Command
load_collector_id
The ID of the load collector to absorb. If specified as 0, all loads in all load collectors are absorbed.
Optional argument specifiying whether value comparison is disabled. Value comparison determines if a given non-uniform load can manifest in a uniform representation. Valid values are:
0 - Value comparison is enabled (default)
1 - Value comparison is disabled
renumber_flag
Option to renumber after absorb:
0 - Do not renumber (default)
1 - Renumber
compression_status
Option to honor the compression status (e.g. certain loads may be on a set or on the actual entitiy, and this state may be honored or expanded). Valid values are:
0 - Do not honor source state (default)
1 - Honor source state
Examples
Absorb and renumber all loads in the model:
*absorbloads 0 0 1 0
Absorb all loads in load collector 5:
*absorbloads 5
Absorb all loads in the model and honor the compression state:
*absorbloads 0 0 0 1
   # Handle error
Version History
2020
