*create_tube_midline
Creates midlines from tube solids.
*create_tube_midline mark=<mark_id> ?dest_comp=<value>? ?copy_metadata=<value>?
HyperMesh Tcl Modify Command
The options can be specified in any order.
- mark=<mark_id>
- The ID of the mark containing the input solids. Valid values are 1 and 2. This is mandatory.
- copy_metadata=<value>
- This specifies whether the metadata is copied from the input solids to the appropriate midline:
- dest_comp=<value>
- This specifies which component the midlines will be created in:
Examples
To extract the midlines from solids 234 and 235 and place the result in the same components as the original solids:
*createmark solids 1 234 235
*create_tube_midline mark=1 dest_comp=original
# Handle error
Version History
2020
