*createmarklast
Populates the mark with the entities used in the last command.
*createmarklast entity_type mark_id
HyperMesh Tcl Modify Command
entity_type
The type of entities to populate.
mark_id
The ID of the mark. Valid values are 1 and 2.
Examples
To determine the new ID of surface 100 after performing a surface offset:
*createmark surfaces 1 105
*createmark lines 1 2471
*offset_surfaces_and_modify surfaces 1 0 1 -3 -0.5
*createmarklast surfaces 1
hm_getmark surfs 1
   # Handle error
