*createplane
Defines a plane for use in a subsequent command.
*createplane plane id normal x normal y normal z base x base y base z
HyperMesh Tcl Modify Command
- plane id
- The ID of the plane being defined (1 or 2).
- normal x
- The x component of the normal of the plane.
- normal y
- The y component of the normal of the plane.
- normal z
- The z component of the normal of the plane.
- base x
- The x component of the base point of the plane.
- base y
- The y component of the base point of the plane.
- base z
- The z component of the base point of the plane.
Examples
*createplane(1,1.0,0.0,0.0,2.0,3.0,4.0)
