*interfaceaddsolidface
Creates interface elements on the face of solid elements.
*interfaceaddsolidface name master element mark node mark break angle
HyperMesh Tcl Modify Command
- name
- The name of the group into which the interface elements should be placed.
- master
- Use 1 for master; 0 for slave.
- element mark
- The ID of the mark containing the solid elements.
- node mark
- The ID of the mark containing nodes that define the face of a solid element.
- break angle
- The angle used to define a "sharp corner".
HyperMesh will use the node mark to find the face of a solid element. All adjacent faces will then be found until a shart corner (defined by a break angle) is found. Finally, master/slave elements will be created on these faces.
None.
