*renamecollector
Renames a collector.
*renamecollector entity type collector name new name
HyperMesh Tcl Modify Command
entity type
The type of collector being renamed.
collector name
The name of the collector to be renamed.
new name
The new name which should be assigned to the collector.
To rename component oldname to newname:
*renamecollector(component,oldname,newname)
None.
