*reviewclearbyid
Removes/clears entities from the review list based on an entity ID.
*reviewclearbyid entity_type id review_type
HyperMesh Tcl Modify Command
This command removes/clears entities from the review list based on an entity ID.
entity_type
The type of entity to add to the review list. Valid values are blocks and groups.
id
The ID of the entity.
review_type
The review type to control.
  • For blocks:
  • 1 = nodes
  • 2 = elems
  • For groups:
  • 1 = slave only
  • 2 = master only
  • 3 = master & slave
To remove master and slave review of group 5 from the review list:
*reviewclearbyid groups 5 3
   # Handle error
