*rundesignmethod
Run the design method for a given design point set.
*rundesignmethod entity_type id=<value>
HyperMesh Tcl Modify Command
Run the design method for a given design point set. The design point set should contain a valid design point and design method.
This outputs a new table entity containing the output of the the operation.
- entity_type
- Must be set to designpointsets.
- id=<value>
- The ID of the design point set.
To run the design method for design point set 2:
*rundesignmethod designpointsets id=2
# Handle error
Version History
2019.1
