*xyplotcurvemodify
Modifies a curve.
*xyplotcurvemodify curve name item name string value plot
HyperMesh Tcl Modify Command
Modifies a curve.
curve name
The name of the curve being modified.
item name
The name of the item of data being modified.
string
The string value of the item.
value
The value of the item.
plot
A logical which determines if the current xy plot should be replotted when the change is made to the curve
None.
