alereferencesystemcurves
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- lcid1
- The first load curve ID.
- lcid2
- The second load curve ID.
- lcid3
- The third load curve ID.
- lcid4
- The fourth load curve ID.
- lcid5
- The fifth load curve ID.
- lcid6
- The sixth load curve ID.
- lcid7
- The seventh load curve ID.
- lcid8
- The eighth load curve ID.
- lcid9
- The ninth load curve ID.
- lcid10
- The tenth load curve ID.
- lcid11
- The eleventh load curve ID.
- lcid12
- The twelfth load curve ID.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
Version History
2019
2020 - Added new data name color_rgb.
