alereferencesystemgroups
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *ALE_REFERENCE_SYSTEM_GROUP
Type: integer
crFlag
The ICR flag.
Type: integer
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entityid
The entity ID.
Type: entity
entitytype
The entity type.
Type: integer
excludedEntityId
The set ID to be excluded from the contraction/expansion.
Type: entity
excludedEntityType
The set type to be excluded from the contraction/expansion.
Type: integer
expansionConstr
The expansion constraint.
Type: integer
groupId
The node group ID.
Type: entity
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
limitRation
The limit ration for mesh expansion/contraction.
Type: double
meshExpCtrFlag
The mesh expansion control flag.
Type: integer
meshPaddFraction
The mesh padding fraction.
Type: double
meshRempFactor
The mesh remapping factor.
Type: double
name
The name of the entity.
Type: string
nodeId
The Lagrangian node ID.
Type: entity
optionalCard
The optional card flag.
Type: Boolean
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
paramID
The parameter ID.
Type: entity
refSysType
The reference system type.
Type: integer
rotationConstr
The rotational constraint.
Type: integer
translationConstr
The translational constraint.
Type: integer
type
The type.
xc
The x-coordinate of the center of mesh expansion/contraction.
Type: double
yc
The y-coordinate of the center of mesh expansion/contraction.
Type: double
zc
The z-coordinate of the center of mesh expansion/contraction.
Type: double
Version History
2019
2020 - Added new data name color_rgb.
