collections
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- collectionlist
- The recursive list of children collection entity IDs.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- entitylist1
- The list of children module entity IDs.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
Version History
14.0.120
