crosssections
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- alpha
- Coefficient for filtering.
- Angle
- Used only for internal graphics purposes.
- attributesmax
- The number of attributes owned by this entity.
- Axis_Node_N2
- Node identifier N2.
- Axis_Node_N3
- Node identifier N3.
- Axis_Origin_Node_N1
- Node identifier N1.
- basenode
- Base node coordinate.
- BeamElementSet_ID
- Beam element set ID.
- CID_Options
- 0 - SYSTEM
- cnode1_x
- Corner node 1 x-coordinate. Valid for hm_getvalue query only.
- cnode1_y
- Corner node 1 y-coordinate. Valid for hm_getvalue query only.
- cnode1_z
- Corner node 1 z-coordinate. Valid for hm_getvalue query only.
- cnode2_x
- Corner node 2 x-coordinate. Valid for hm_getvalue query only.
- cnode2_y
- Corner node 2 y-coordinate. Valid for hm_getvalue query only.
- cnode2_z
- Corner node 2 z-coordinate. Valid for hm_getvalue query only.
- cnode3_x
- Corner node 3 x-coordinate. Valid for hm_getvalue query only.
- cnode3_y
- Corner node 3 y-coordinate. Valid for hm_getvalue query only.
- cnode3_z
- Corner node 3 z-coordinate. Valid for hm_getvalue query only.
- cnode4_x
- cnode4_y
- cnode4_z
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- cutplanegeometry
- 0 - Infinite plane
- cornernode1
- Corner node 1 coordinate.
- cornernode2
- Corner node 2 coordinate.
- cornernode3
- Corner node 3 coordinate.
- cornernode4
- Corner node 4 coordinate.
- cs_controlpoint
- The control point attached to the cross-section.
- cs_parentbelt
- The seatbelt parent to which the cross-section is attached.
- CSNode_N1
- The node ID at point A.
- CSNode_Ns
- The node ID at point B.
- CSsetId
- The element set ID to be cut by the cutting plane to generate an element-based surface that approximates the cutting plane.
- definedentity
- True if the entity is defined, false otherwise.
- Definition
- If true, defines the cutting plane by giving coordinates. Defines using global nodes otherwise.
- deltaT
- Time step for saving the data.
- DisplayMode
- The direction of the section cut.
- DiscreteElementSet_ID
- Discrete element set ID.
- Edge
- Edge vector coordinate.
- elementities
- Master entity IDs.
- elementities_count
- The number of master entity IDs.
- elementities_type
- The type of master entity IDs.
- file_name
- Root file name containing the output.
- geometrytype
- The type of geometry for the entity.
- Infinite plane
- Finite plane
- Circle
- Parallelogram
- GID_Options
- 0 - CENT (coordinate system is shifted to the centroid of the section)
- grbeam_id
- The ID of the beam group.
- grbrick_id
- The ID of the brick group.
- Grnod_id
- The ID of the node set.
- grshel_id
- The ID of the shell group.
- grsprg_id
- The ID of the spring group.
- grtria_id
- The ID of the tria group.
- grtrus_id
- The ID of the truss group.
- grbrick_id
- idesph
- Flag for deactivation of associated SPH elements.
- Iframe
- Computing the skew center local skew is the skew flag defined by node_ID1, node_ID2, and node_ID3.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- int_id
- Optional interface identifiers if Niter > 0
- internalid
- Intersect_Flag
- ISAVE
- Data save flag.
- Length
- Value of length.
- name
- The name of the entity.
- Niter
- The number of interfaces.
- NodalSet_ID
- Node set ID.
- nodeentities
- Slave entity IDs.
- nodeentities_count
- The number of slave entity IDs.
- nodeentities_type
- The type of slave entity IDs.
- nodeentities_2
- Slave 2 entity IDs.
- nodeentities2_count
- The number of slave 2 entity IDs.
- nodeentities2_type
- The type of slave 2 entity IDs.
- normal
- Normal direction coordinate.
- Normal_x
- Normal x-direction coordinate. Valid for hm_getvalue query only.
- Normal_y
- Normal y-direction coordinate. Valid for hm_getvalue query only.
- Normal_z
- Normal z-direction coordinate.Valid for hm_getvalue query only.
- Offset
- The offset distance to the origin (0,0,0) for infinite and finite plane cutplanegeometry.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- Radius
- Value of the radius.
- secfotype
- The type of output.
- Section_Type
- Identifies the type of section generated using options.
- sectiontypetoggle
- 0 - Default blank value of type of section
- setIdMax
- The number of set IDs. Valid for hm_getvalue query only.
- ShellElementSet_ID
- Shell element set ID.
- SolidElementSet_ID
- Solid element set ID.
- System_ID
- Moving frame identifier.
- ThickShellElementSet_ID
- Thick shell element set ID.
- vcrit
- The value for the selected type of criterion.
- VisualizationPart_ID
- Part set ID.
- VolumeFractionType
- The type of volume fraction criterion.
- Width
- Value of width.
- XHead
- Normal x-direction graphics head coordinate. Valid for hm_getvalue query only.
- XHev
- Edge x-direction graphics head coordinate. Valid for hm_getvalue query only.
- XTail
- Base node x-coordinate. Valid for hm_getvalue query only.
- YHead
- Normal y-direction graphics head coordinate. Valid for hm_getvalue query only.
- YHev
- Edge y-direction graphics head coordinate. Valid for hm_getvalue query only.
- YTail
- Base node y-coordinate. Valid for hm_getvalue query only.
- ZHead
- Normal z-direction graphics head coordinate. Valid for hm_getvalue query only.
- ZHev
- Edge z-direction graphics head coordinate. Valid for hm_getvalue query only.
- ZTail
- Base node z-coordinate. Valid for hm_getvalue query only.
Version History
2017.1 - Added new data names cutplanegeometrytype, DisplayMode and offset.
2017.2 - Added new data names Section_Type and sectiontypetoggle.
2019 - Added config 401. Added new data names cnode3_x, cnode3_y, cnode3_z, cnode4_x, cnode4_y, cnode4_z, cornernode3, cornernode4, elementities, elementities_count, elementities_type, idesph, nodeentities, nodeentities_count, nodeentities_type, nodeentities_2, nodeentities2_count, nodeentities2_type, secfotype, vcrit and VolumeFractionType.
2019.1 - Added new data names CID_Options and GID_Options.
2020 - Added new data names color_rgb, cs_controlpoint, cs_parentbelt, CSNode_N1, CSNode_N2, CSsetId, Definition and setIdMax.
