designpointmethods
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
category
The category of the entity:
panel_composite
panel_metallic
rivet
spring
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
designmargin
Specifies how the design margin is presented in results for the First Ply Failure method. Valid values are:
"Inverse Reserve Factor / Failure Index"
"Margin of Safety"
"Reserve Factor / Factor of Safety"
Type: string
dkifoam
The material IDs to be processed by this failure function for the First Ply Failure method.
Type: entity array
hashin
Type: entity array
hoffman
Type: entity array
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
larc
Type: entity array
maxfiberstress
Type: entity array
maxshearstress
Type: entity array
maxstrain
Type: entity array
maxstress
Type: entity array
method
The name of the method.
First_Ply_Failure - For panel composite using ESACOMP
JointLoad - For rivet
Panel_FailureMode - For panel metallic using tensile/compressive failure
Panel_ShearBuckling - For panel metallic using shear buckling method
Type: string
name
The name of the entity.
Type: string
outofplaneshear
Type: entity array
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
platform
The method engine. Valid values are:
compose
dll
internal
matrix
python
tcl
Type: string
puckcf
Type: entity array
puckgf
Type: entity array
resultlevel
Specifies the amount of result data generated by the First Ply Failure method. Valid values are:
Element
Layer
Recovery_plane
Type: string
tableid
The IDs of the method debug data tables.
Type: entity array
tsaihill
Type: entity array
tsaiwu
Type: entity array
vonmises
Type: entity array
wrinklingfoam
Type: entity array
wrinklinghoneycomb
Type: entity array
yamadasun
Type: entity array
Version History
2019.1
2020 - Added new data names color_rgb, designmargin, dkifoam, hashin, hoffman, larc, maxfiberstress, maxshearstress, maxstrain, maxstress, outofplaneshear, puckcf, puckf, resultlevel, tableid, tsaihill, tsaiwu, vonmises, wrinklingfoam, wrinklinghoneycomb and yamadasun. Added new category values panel_composite and panel_metallic.
