gauge
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- componentlist
- The list of property IDs associated with the designvar (pointer value is property ID).
- componentlistmax
- The number of properties referenced by the designvar.
- config
- The configuration of the entity.
- configname
- The solver keyword for the designvar. Valid for hm_getvalue query only.
- definedentity
- True if the entity is defined, false otherwise.
- delxv
- The move limit of the designvar. If -1, the move limit is unset/blank.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- initialvalue
- The initial value of the designvar.
- lowerbound
- The lower bound of the designvar.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- propertylist
- type
- The ID of the assigned ddval.
- upperbound
- The upper bound of the designvar.
