elementclusters
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- elem_type
- The element type of the entity.
- exponents_b1
- Multidirectional failure exponent.
- exponents_b2
- exponents_b3
- exponents_b4
- fn_fail1
- The node identifier.
- fs_fail
- The x-coordinate of the normal vector tail.
- group_ID
- The ID of the group identifier.
- ifail
- The failure model option.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- mb_fail
- The z-coordinate of the normal vector tail.
- mt_fail
- The y-coordinate of the normal vector tail.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- scalefactor_a1
- Multidirectional failure scale factor.
- scalefactor_a2
- scalefactor_a3
- scalefactor_a4
- skew_ID
- The ID of the skew identifier.
Version History
2019
2020 - Added new data name color_rgb.
