rbe3
Unless otherwise specified, data names are accessible in level 3 only.
- attributesmax
- The number of attributes owned by this entity.
- centerx
- The x coordinate of the element centroid.
- centery
- The y coordinate of the element centroid.
- centerz
- The z coordinate of the element centroid.
- collector
- Pointer to the collector that owns the element.
- config
- The configuration of the entity.
- dependentcoeff
- The dependent coefficient/weighting factor.
- dependentdof
- The dependent node degrees of freedom, consisting of the values 1-6.
- dependentnode
- Pointer to the dependent node.
- definedentity
- True if the entity is defined, false otherwise.
- dofs
- The degrees of freedom at the dependent node, consisting of the values 1-6. Type: integer.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- independentcoeffs
- Pointer to the independent coefficients.
- independentcoeffsmax
- The number of independent coefficients.
- independentdofs
- Pointer to the independent degrees of freedom.
- independentdofsmax
- The number of independent degrees of freedom.
- independentnodes
- Pointer to the independent nodes.
- independentnodesmax
- The number of independent nodes.
- nodecount
- The number of nodes for the element. Valid for hm_getvalue query only.
- nodes
- The list of nodes for the element. Valid for hm_getvalue query only.
- type
- The solver dependent type code for the entity.
- typename
- The solver dependent type name for the entity.
