weld
Unless otherwise specified, data names are accessible in level 3 only.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
centerx
The x coordinate of the element centroid.
Type: double
centery
The y coordinate of the element centroid.
Type: double
centerz
The z coordinate of the element centroid.
Type: double
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
config
The configuration of the entity.
3 - weld
Type: unsigned integer.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dofs
The degrees of freedom, consisting of the values 1-6. Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
length
The length of the element. Type: double.
node1
Pointer to the independent node of the element. Type: pointer (levels 2, 3 and 4).
node2
Pointer to the dependent node of the element. Type: pointer (levels 2, 3 and 4).
nodecount
The number of nodes for the element. Valid for hm_getvalue query only.
Type: integer
nodes
The list of nodes for the element. Valid for hm_getvalue query only.
Type: entity array
type
The solver dependent type code for the entity.
Type: integer
typename
The solver dependent type name for the entity.
Type: string
